When I try to use getchar, the program just hangs. It seems as though the bit in the U0LSR register that says data is in the RDR register is not being set.
printf works just fine as I can see everything I need to see in hyperterminal. So I know data is being transmitted, I'm just not sure if data is being received. Heres the modified getchar function.
int getchar (void) { /* Read character from Serial Port */ while (!(UART0_LSR & 0x01)); return (UART0_RBR); }
Hi the code fragment you posted looks fine, are you sure the RX is enabled. Here follows code that works, for none interupt use I think you only need to set PINSEL0, U0LCR, U0DLL, U0LCR. Just use the simulator to check things are working.
void serial_init (void) { PINSEL0 = 0x00000005; // Enable RxD0 and TxD0 U0LCR = 0x83; // 8 bits, no Parity, 1 Stop bit U0DLL = 8; // 115200 Baud Rate @ 15MHz VPB Clock U0LCR = 0x03; // DLAB = 0 U0FCR = 0x87; // RX interrupt at 8 chars U0IER = 0x03; // Enable RDA and THRE interrupts VICVectAddr14 = (U32)int_serial; VICVectCntl14 |= 0x20 | 0x06; // Enable VIC with index 7 VICIntEnable |= 0x40; // VIC Chnl#7 sendstop = __FALSE; // CtrlQ not received ridx = widx = 0; // clear buffer indexes }
