I have the idea to replace RS-232 line between embeded system and PC with Bluetooth (to provide same transfer rate). I use XC167-16 and PLD on board. I'm a beginner in wireless technologies and finding the most simple (in programming) and low-cost solution in small dimension (like controller). Please help me with any advice and references.
You will have to do some research and see what's available! Ideally, Select one that provides a transparent link; ie, as far as the C167 is concerned, it can't tell that it's not connected by a direct RS232 cable!
Thanks for details. Does conrolling bluetooth module by C167 bring to using of TxD and RxD ports?
Get a bluetooth-to-RS232 converter module (for the PC) and a bluetooth-to-async-data (for the embedded side).
