The following is the code to turn motors in the forward direction (for a robot). The problem is that the motors dont pause for the delay1() which is a 1 sec delay. Instead it goes one turning without pause. it never breaks the loop. Could you people please help as it is urgent.
/*----------------------------------------------------------------------------- Definitions for P1 (8 bits), P1.0 to P1.7. -----------------------------------------------------------------------------*/ sfr P1 = 0x90; /* SFR for P1 */ sbit P1_0 = P1^0; /* SFR for P1.0 */ sbit P1_1 = P1^1; /* SFR for P1.1 */ sbit P1_2 = P1^2; /* SFR for P1.2 */ sbit P1_3 = P1^3; /* SFR for P1.3 */ sbit P1_4 = P1^4; /* SFR for P1.4 */ sbit P1_5 = P1^5; /* SFR for P1.5 */ sbit P1_6 = P1^6; /* SFR for P1.6 */ sbit P1_7 = P1^7; /* SFR for P1.7 */ /*------------ Declaration of the various functions ------------------*/ void forward(); /* Function to move forward one cell. */ void delay(); /* Function Delay 1 - For Motor Speed */ void delay1(); /* Function Delay 2 - For Pause */ void delay(); /*----Declaration of variables---------------*/ unsigned int i; /*----------------------------------------------------------------------------- MAIN C function -----------------------------------------------------------------------------*/ void main (void) { while (1) { forward(); delay1(); delay1(); } } void forward() // Setting Bits individually to move forward { for(i=50 ; i>0 ; i--) { P1_0 = 0; P1_1 = 0; P1_2 = 0; P1_3 = 1; P1_4 = 1; P1_5 = 0; P1_6 = 0; P1_7 = 0; delay(); P1_0 = 0; P1_1 = 0; P1_2 = 1; P1_3 = 0; P1_4 = 0; P1_5 = 1; P1_6 = 0; P1_7 = 0; delay(); P1_0 = 0; P1_1 = 1; P1_2 = 0; P1_3 = 0; P1_4 = 0; P1_5 = 0; P1_6 = 1; P1_7 = 0; delay(); P1_0 = 1; P1_1 = 0; P1_2 = 0; P1_3 = 0; P1_4 = 0; P1_5 = 0; P1_6 = 0; P1_7 = 1; delay(); } return ; } void delay() /* Delay function 1 - For Motor Rotation */ { #pragma asm del: mov r0,#028h two: mov r2,#04bh one: mov r1,#01h again: djnz r1,again djnz r2,one djnz r0,two #pragma endasm return; } void delay1() /* Delay function 2 - For Pause */ { #pragma asm del1:mov r0,#0e1h tw:mov r2,#0eah on:mov r1,#08h ag:djnz r1,ag djnz r2,on djnz r0,tw #pragma endasm return; }
Pay attention to the linker error.You may need to add followings: INIT.A51 and STARTUP.A51. BTW,why not using a function like this: void Delay() { uchar ii,kk,jj; for (ii==0x28;ii>0;ii--) for (jj=0x4b;jj>0;jj--) for (kk=2;kk>0;kk--) {}; }
