Hi, I am generating pulse output through 8051 microcontroller using assembly langauge. I don't wnat to use any timer for time delay, I would like to use instruction delays as follows... CLR portbit......3 cycles NOP..............1 cycle NOP..............1 cycle NOP..............1 cycle SETB portbit.....3 cycles NOP..............1 cycle NOP..............1 cycle NOP..............1 cycle CLR portbit......3 cycles 6cycles ---| |-------| |-------| | 6cycles OFF time = 1+1+1+3 ON time = 1+1+1+3 Is it my calculation is correct here?. SETB portbit.....3 cycles will be added into OFF time or ON time? Please comment on this... Thanks in advance Rajesh
Hi, In the above posting please ignore the waveform... ************************ 6cycles ---| |-------| |-------| | 6cycles *********************** I have tried to create waveform with ON and OFF times. But it was become something else after posting it. thanks Rajesh
well, the least you could do would be to verify the cycles you calculate with in "the bible". If you state the wrong cycle count for an instruction, the total will be off as well. Erik
