Hi, I want to assign absolute address to one of my array. eg. i want to assign the array named as test_ary[] in code memory from 0x1000 location. How can i do it ? unsigned char code test_ary[]={ 0x12, 0x11, 0xFE, 0x22, 0xDE, 0x65, 0x98, 0x22, 0x43, 0x21, ... ... ... }; Here, test_ary is an image of executable code. I want to locate this image i.e test_ary from 0x1000 address in code memory using _at_ keyword. How can i do it ? Thanks in advance.
Last I looked, the tools didn't support using _at_ for this. But you can still use the original method for which _at_ is really just syntactical sugar: put the initialized array into a separate source file, and use linker controls to move it where you need it.
Is this a limitation of Keil that we cant use _at_ for initialized array ? Well, using linker control i can do it. But my problem is that i have a conditional initialization for such array like: #ifdef COND1 //Initialize test_ary from 0x1000 #else //Initialize test_ary from 0x2000 #endif Is it possible to do this with _at_ keyword ?
"Is this a limitation of Keil that we cant use _at_ for initialized array?" Well, let's just take a look at the Manual, shall we? http://www.keil.com/support/man/docs/c51/c51_le_absvarloc.htm Which part of "Absolute variables cannot be initialized" is unclear?
