Hi, Currently iam working on c51 in dos mode ,where am not able to debug my code.Plz can anybody tell me which is best platform to work on c51 which has debugging option.Iam using AT89C51RD2. regards, Srinivas k.r
Thanx guys 4 tht inofrmation.Can u plz tell me whether can i use microvision IDE to run my program and debug it.Whts ur opinion on tht. regards, Srinivas K.r.
Can u plz tell me Since you specificall ask if "micro" can tell you, why do you not e-mail him instead of pestering the forum? Erik
Thanx 4 ur response ,Am able to compile my code in microvision IDE but am getting error L229 -INTERNAL ERROR.Can any body tell me wht is procedure to compile,link and generate .hex file in Micorvision3 IDE.I have one .c file i.e., source file and one .lib file which i need to link with .obj and then generate .hex file.Waiting 4 reply. srinivas K.r.
Nobody will tell you in details.. So best way is to go through the manuals provided by Keil.
"Thanx 4 ur response" Do you have some physical disability that makes it hard for you to type "for" and "your" and "what", etc? If not, why should people bother to put any effort into answering your queries if you can't even be bothered to type a few extra vowels?? "am getting error L229 -INTERNAL ERROR" Is that precisely what the message says? Don't re-type it (we know you find typing difficult) - use copy-and-paste. You can look-up all the error messages in the Manuals: http://www.keil.com/support/man/docs/bl51/bl51_l229.htm http://www.keil.com/support/man/docs/lx51/lx51_l229.htm In this case, they tell you exactly what to do! "Can any body tell me wht is procedure to compile,link and generate .hex file in Micorvision3 IDE" Yes - the Manuals tell you precisely that, and also contain step-by-step worked projects to illustrate the process!
Do you have some physical disability that makes it hard for you to type "for" and "your" and "what", etc? This reminds me I worked at a company that got cited for not adhering to a regulation and as a result painted "handicapped only" on some parking spaces, NOTHING happened, everybody parked as they used to. Then "physically handicapped only" was painted and the spaces stood empty. Erik
