Q1:i build the flash algorithm's project in Keil/arm/Flash/sub-folder and get *.flx file in keil/arm/flash.but when i want to Use the Add button in the Configure Flash Download dialog to add this programming algorithm file to the µVision project of the target application,i found it isn't there. how about it? Q2: I am trying to get support for a programming algorithm for a ST ARM device, we need a STR73X.FLX file which Keil have agreed to supply.Could you please supply this file as soon as possible........we need this very urgently ! Thanks a lot!!
Hi,Matthias: I think i get what the problem is. when i use realview complie to get *.flx file in vision 2.50a ,it can not be used in flash download dialog. But when i use ads to compile it work well. Thanks any way,Matthias!
Where should we send the FLX to?
