I am trying to troubleshoot a project containing 2 targets which communicate over a CAN bus on Si Labs' C8051F04x CPUs with Keil's uVision3 environment. When running in edit mode, I can always see which target is active by looking at the selection line in the Build toolbar. But when I switch to debug mode, the toolbar disappears and I have found no way to tell which target is active. I have already loaded code into the wrong board once, and worry how well I will be able to keep track of it when I may have to switch among 5 targets. Has anyone figured out a way to tell them apart (other than switching to Edit mode & back again)? Thanks. ============================================================ Gary Lynch | To send mail, change no$pam in lynchg@no$pam.com | my domain name to stacoenergy
How about something like
#if defined( DEBUG ) char signature[]="DEBUG "; #elif defined( RELEASE ) char signature[]="RELEASE"; #else #error "Must be Release or Debug!" #endif
On 2/20/06 16:20:35; A.W. Neil wrote: > > How about something like > #if defined( DEBUG ) > char signature[]="DEBUG "; > #elif defined( RELEASE ) > char signature[]="RELEASE"; > #else > #error "Must be Release or Debug!" > #endif > and keep a Watch set on the signature string? > I hadn't thought of that. I will probabably have to put something in like that in there for production reasons anyway. I'll interpret this to mean there is nothing in uVision 3 to tip me off. > > PS Why do you always put your whole post in "code" mode? > When I started posting (over 10 years ago: on UseNet), all communication was in plain ASCII and there were conventions for most formatting types that I grew quickly comfortable with. In addition I could create tables with aligned columns using the space bar, insert ASCII art, much as I did in block comments in my code; e.g.: > > /* + + + + + + + + + + + + + + + + + + + + + + + + + + + */ > /* Because of the CAN engine's */ > /* auto-increment feature, we 0xD8 0xD9 */ > /* must take care when READING +----------+----------+ */ > /* the 16-bit CAN0DAT_1 | CAN0DATL | CAN0DATH | */ > /* register. It looks like an +----------+----------+ */ > /* SFR16, stored in little \ / */ > /* Endian format; but the Keil \ / */ > /* guarantee to always access \/ */ > /* the low byte last only /\ */ > /* applies to WRITE operations / \ */ > /* to SFR16's. The read order is |/_ _\| */ > /* unpredictable. +----------+----------+ */ > /* | regData | */ > /* Keil's native format for +----------+----------+ */ > /* unsigned int's is big Endian, 0x15 0x16 */ > /* which may make this transfer */ > /* look confusing. */ > /* + + + + + + + + + + + + + + + + + + + + + + + + + + + */ > (I cut & pasted that straight out of a source file.) I now post on several of these web forums, each of which implements a unique subset of something resembling HTML, and I don't want to keep track of which group I am in, or what part of my message needs which markups, so I put the whole thing between those tags, it looks just like ASCII, and works everywhere. Thanks for the insight. ============================================================ Gary Lynch | To send mail, change no$pam in lynchg@no$pam.com | my domain name to stacoenergy
When running in edit mode, I can always see which target is active by looking at the selection line in the Build toolbar. But when I switch to debug mode, the toolbar disappears and I have found no way to tell which target is active. That toolbar disappears by default, but nothing's stopping you from turning it on again. Just tick the entry "build bar" in the View menu, and that's that. uVision keeps mostly separate sets of GUI settings for edit and debug mode. Not excessively intuitive the first time round, and AFAIK not documented anywhere, but it works ;->
You are right! Herzlichsten Dank! ============================================================ Gary Lynch | To send mail, change no$pam in lynchg@no$pam.com | my domain name to stacoenergy
