hi all, i am getting data from serial port so it is in character form my function is like this <per> { idata char arr[15]={0}; int i,j; arr[i++]=getkey(); while(( arr[i++] = getCharX())!=0xff && i<11){ //Get Ack package } i=(arr[2]/0x10)>0x09?(arr[2]/0x10)+55:(arr[2]/0x10)+48; j=(arr[2]%0x10)>0x09?(arr[2]%0x10)+55:(arr[2]%0x10)+48; display(i); display(j); } void display(char s) { ... ... return; } </per> The value is hex which I convert and move into i and j I can see the value properly on LCD but can not perform operation on it as an integer please suggest how i can convert this value into integer ex- 56 is moved as 5 & 6 into i & j respectively but i want to convert them to decilmal please help. Thank you. Ajay
void BinToDec(unsigned char) { unsigned char powTen; unsigned char i; unsigned char digit; for (i = 0; i != DIM(PowTenTbl); i++) { digit = 0; powTen = PowTenTbl[i]; while (bin >= powTen) { bin -= powTen; digit++; } display(digit + '0'); } } { ... BinToDec(arr[2]) }
Didn't paste enough...
#define DIM(a) (sizeof(a) / sizeof(a[0])) unsigned char PowTenTbl[] = { 100, 10, 1 };
