Using Memory Window in Debugger...
I'm trying to debug a problem where the value of a pointer is being changed when I don't expect it to. I was having trouble getting the debugger to display the value of the pointer in files other than where it was declared, even after I made it a global variable (just to debug the problem). I kept getting a message that it was out of scope.
So... I tried a different approach, and that's what this question's about.
I looked in the map file and saw that the value of this pointer was 0x002000A8, the class was DATA, and the type was '---' (whatever that means). I then started the debugger and entered the value of 0x002000A8 into the Address field of the Memory #1 window. When the code stopped on the breakpoint on the line where I assigned a value to that pointer, the data at the associated memory location did not change. However, the same variable displayed in a watch window did change, and to what I expected.
Is there some trick to getting the memory window to update, to show that the data at that location has indeed changed? Or, am I not understanding how to read the map file and use the memory window to show changing data in RAM?
HELP... (thanks).
