Hi, Is there an option to enable viewing of enum values in the debugger? For example, typedef enum {false=0, true} FalseTrueType; In the c souce... FalseTrueType MyEnumFlag = false; I would like to view this in the debugger watch window. Name Value MyEnumFlag false but I can only view it as (not Symbolically) Name Value MyEnumFlag 0 Thanks, Chris
Just to add my two cents to the wish, I find it's often useful to be able to see the actual value as well as the symbolic value. So how about a debugger display such as: someEnum: false(0) so that we can see both at once, rather than just symbol or value?
"So how about a debugger display such as: someEnum: false(0)" Just noticed that Borland does, in fact, do exactly this! I suspect the Keil (C51, at least) doesn't generate debug info for this - so the debugger can't display it. (maybe it's a limitation of OMF...?)
