unsigned char far ff1 _at_ 0x010001; unsigned char far ff2 _at_ 0x020001; unsigned char far ff3 _at_ 0x030001; void main () { ff1 = 0x20; ff2 = 0x30; ff3 = 0x40; } Code Optimization: level 8 when compiled->linked generate code below: 6: void main () 7: { ff1 = 0x20; 0x800019 7420 MOV A,#0x20 0x80001B 7B01 MOV R3,#ff2(0x01) 0x80001D 7A00 MOV R2,#0x00 0x80001F 7901 MOV R1,#ff2(0x01) 0x800021 A558 EMOV @PR0+0,A 8: ff2 = 0x30; 0x800023 7430 MOV A,#0x30 0x800025 A558 EMOV @PR0+0,A 9: ff3 = 0x40; 0x800027 7440 MOV A,#0x40 0x800029 A558 EMOV @PR0+0,A 10: } 0x80002B A522 ERET the result is ff1:0x40 ff2:0x00 ff3:0x00 Is this an BUG?
CPU: P89C669 ROM: Huge 8MB Memory Model:Small EAM EQU 1 ESMM EQU 1 EIFM EQU 1
I report this bug, But no keil's reply, Why?
Keil support doesn't monitor this forum for bug reports. There are a couple of Keil employees that do read the board and answer questions, but by and large it's a user forum. I've always gotten good results contacting Keil support via email. They'll want you to attach a .zip file with a small project that illustrates the problem. http://www.keil.com/support/bugreport.htm http://www.keil.com/support/email.htm
