Porting STR Webserver Example to Keil
i want to port the STR912F webserver example from St with the uip stack to Keil. Unfortunately the startup files 91x_init.s and 91x_vect.s could not be assebled by ulink 3 it seems that Keil ist incompatible to this files. By using the STR91x startup file from Keil the webserver don´t works.
Has anyone a hint for solving this problem?
Björn
  • "the startup files 91x_init.s and 91x_vect.s could not be assebled by ulink 3"
    You mean uVision3?
    What do you mean, "could not be assebled"?
    What errors did you get?
    "By using the STR91x startup file from Keil the webserver don´t works."
    So look at the other startup files, see where they differ, and make the appropriate changes...
    You mean uVision3?
