Hi folks
I like to use the simulator for testing parts of the software. A DLL handling the I2C 'world' is running, but can't read data.
I have a problem with the interrupts after sending the device address. Start-condition works Address-interrupt happens. But then the real hardware clocks 8 bits plus Ack or NACK into the processor and the next interrupt happens. So here is my problem putting 9 bits into the VTREG. Values from 0 to 255 are data. Value FF00 is ACK Value FF01 is NACK
So I don't know how it's work. How should I return data and the ACK/NACK with one interrupt inside the AGSI-Call?
I know You know ;-) Günter
