TOOL: RVMDK V3.02a, with RealView V3.0 compiler.
I use uC/OS-II in this program. Please mail to me for a complete example. huawdg@pub.wx.jsinfo.net
Code in system_task.c:
#include <LPC22xx.H> #include "includes.h" #include "generictype.h" #include "rt_locale.h" #include "locale.h" void IRQ_Exception(void) { VICVectAddr=0; } void timer0_Exception(void) { T0IR = 0x01; OSTimeTick(); VICVectAddr=0; //interrupt routine finish } void TaskIdleHook(void) { } void DAbt_Handler(void) {} void PAbt_Handler(void) {} void Undef_Handler(void){} void FIQ_Handler(void) {} extern void IRQ_Handler(void); extern void timer0_Handler(void); #define SIZE_TASKSTART_STK 800 static OS_STK TaskStartStk[SIZE_TASKSTART_STK]; //timer0: 10ms void timer0_Init(void) { T0IR = 0xffffffff; T0TC = 0; T0TCR = 0x01; T0PR = 0; T0MCR = 0x03; T0MR0 = 110592; } void VICInit(void) { VICIntEnClr = 0xffffffff; VICDefVectAddr = (unsigned long)IRQ_Handler; VICVectAddr1 = (unsigned long)timer0_Handler; VICVectCntl1 = (0x20 | VICINT_NUM_TIMER0); VICIntEnable = 1 << VICINT_NUM_TIMER0; } void task_Start(void *pdata) { char s[100]; VICInit(); timer0_Init(); sprintf(s,"float=%f",12.345); //wrong result sprintf(s,"float=%f",8871.5678); //wrong result while(1); } int main(void) { setlocale(LC_ALL,"C"); VICIntEnClr = 0xffffffff; OSInit(); OSTaskCreate(task_Start, (void *)0, &TaskStartStk[SIZE_TASKSTART_STK - 1], 5); OSStart(); return 0; } void _sys_exit(int return_code) { label: goto label; /* endless loop */ }
Do you have your stack 8-byte aligned? Floating point in RealView compiler requires 8-byte aligned stack. If this is not the case you might get the results you are seeing.
Franc
The stack is 8-byte aligned. This is an example. bbs.21ic.com/.../200682885943927.zip
You still haven't answered Dan's original questions...
