How to insert Assenbly CODE in between function???
I am using AT89C51ED2 Micro controller, I want to insert assembly code in between the EEPROM fucntion,
The function is,
void EEPROM_WRITE(unsigned char xdata *Addr,unsigned   int E_Data )
unsigned char Buffer[10],i=0;
sprintf(Buffer,"%d",(int)E_Data);
   while(Buffer[i]!='/0')
      while(BUSY);
      EA=0;
      E_EEPROM; // EEPROM Enable Macro
      *(Addr+i)=Buffer[i];  // Replace this code with    Assmebly in code???
      EA=1;
      D_EEPROM; // EEPROM Disable Macro
      i++;
     *(Addr+i)='\0';
If there is any problem in the code , please correct !!
and please tell me how can we replace the code in assembly in between the code???
Rajesh
