Hi all, Our project uses the HLARGE memory model. I'm trying to run the (received but not very well documented) application from RAM instead of flash by copying it to RAM in the startup.a66 file. And now I'm running into some problems and I'm not sure if it's caused by a lack of C167 knowledge, or lack of application/dependency knowledge. Probably both :-) My questions: What is the difference between strlen() and xstrlen() (or x...() functions in general)? Why wouldn't I be able to use strlen() (which is standard C right?)? What situations require xstrlen() to be used and what would go wrong if you don't? If you have a regular declared character array:
static const g_u8_typ crc_TEST_STRING[]= "THE,QUICK,BROWN,FOX,0123456789" ;
Sorry for the double-post in the forum... The forum/Keil site was acting very strange that day...
See http://www.keil.com/forum/docs/thread8090.asp
