Loading multiple .omf into uVision3
Is there a way to load multiple absolute .omf files into the uVision3 simulator? Or, alternatively, is there a tool to combine multiple absolute .omf files into a single absolute .omf file?
  • Is there a way to load multiple absolute .omf files into the uVision3 simulator?
    Unless something broke rather recently: no. Just use the debugger internal command "load" more than once, in your debug session's .ini script.
    There's a drawback, though: only the symbols from the last file you load will be reachable in the debugger. I usually just loaded the .hex files instead.
