Squaring floating point values
Hello Everybody,
Iam facing a strange problem with floats and their mathematical operations
i recive a string of data through serial port( 20bytes i.e 5 float values)
so to do mathematical operation on these floating values i needto see the raw bytes in floating values to do that i created a union like below
union {
unsigned char FB[4];
float value;
long value1;
}convert1;
now i use convert1 to use the raw bytes for my calculations like below
float val1 = 0;
float LAST_val1 = 0;
float val2 = 0;
float LAST_val2 = 0;
float val3 = 0;
float val4 = 0;
float DIFFERANCE = 0;
Get_Difference(){
convert1.FB[0] = BUFFER[0];
convert1.FB[1] = BUFFER[1];
convert1.FB[2] = BUFFER[2];
convert1.FB[3] = BUFFER[3];
val1 = convert1.value;
val1 = (val1*180)/PI;
val4 = val1 - LAST_val1;
LAST_val1 = (convert1.value*180)/PI;
convert1.FB[0] = BUFFER[4];
convert1.FB[1] = BUFFER[5];
convert1.FB[2] = BUFFER[6];
convert1.FB[3] = BUFFER[7];
val2 = convert1.value;
val2 = (val2*180)/PI;
val3 = val2 - LAST_val2;
LAST_val2 = (convert1.value*180)/PI;
val4 = sqrt(val4*val4 + val3*val3);
if( val4 < 0.01) DIFFERANCE = DIFFERANCE + val4;
i am calling the Get_Differance(); function many times in my application
The problem i am facing is that the val4 = sqrt(val4*val4 + val3*val3)
is some time not comming correct
i am also monetring the values on my PC ie.the whole buffer is sent to an application on pc which shows the expected values but not inside the micro
is there some thing wrong with squaring of floating point number?
should i use a function for that?
pls help
