Hi, I am using LARGE memory model for my project and so i enable reentrant stack in xdata by defining it in startup.a51 file as XBPSTACK EQU 1 Some of my function are defined reentrant for small memory and some by default in large memory model. for example: void func1(void) reentrant and void func2(void) small reentrant. Here, will the reentrant stack for func2 be allocated in xdata or idata ? as memory model is small for this func2, should i enable reentrant stack in both memory like: XBPSTACK EQU 1 IBPSTACK EQU 1 Is this possible ? Thanks in advance.
Yes, you can define it in both memory.
Yes, you can define it in both memory. you can if speed is of no concern. You will see a considerable slowdown by having the stack in XDATA. Erik
