RTX Tiny Performance
Two questions about RTX51 Tiny performance (Note: I have Round Robin disabled):
1) In the Overview section of the User's Guide, it lists context switch time as "100..700 cycles". In terms of execution time, that's like saying "bigger than a bread basket, smaller than a mountain". Can anyone expound upon the context switch time a bit? What factors contribute to this?
2) With round-robbin disabled, how many cycles does the RTX timer interrupt consume? I'm not taking about the interrupt latency the manual lists, rather cycles (min/max range thereof) the timer interrupt itself consumes.
  • 1) In the Overview section of the User's Guide, it lists context switch time as "100..700 cycles". In terms of execution time, that's like saying "bigger than a bread basket, smaller than a mountain". Can anyone expound upon the context switch time a bit? What factors contribute to this?
    RTX51 Tiny manages all task stacks in IDATA memory. When switching to a new task, the kernel moves the other task stack out of the way. This may be fast (if there are few tasks with short stacks) or it may be slow ( is there are many tasks with large stacks). Refer to the following manual page for a description of how this works.
    http://www.keil.com/support/man/docs/tr51/tr51_stackmgmt.htm
    I think this is the main contributor to task switch times.
    That I don't know. However, I believe it will take less because most (if not all) functionality is there even with round-robin enabled.
    Jon
    Jon
