Using an Array
Hi I have the following array declared at the start of my program as global:
int number[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x98};
0 1 2 3 4 5 6 7 8 9
It is for a 7 segment display to display the numbers that I need, the array is from 0-9 in that order.
My code to call the array is:
P2 = number[4];
so in this case it should get the 4th number being 0x99
This works fine if i replace the 4 with 0,1 or 2 but anything greater than 2 all it does is return the data for 8 (80)
If anyone can work out why this is doing this please let me know
