Hi, Iam new to the microcontrollers,could u pls explain what is the difference b/w Interrupt and functions in embedded programing........
This is basic knowledge and is not specific to Keil SW. You may check Wikipedia'a entry on interrupt routines: http://en.wikipedia.org/wiki/Interrupt_routines
An Interrupt is a feature of the processor hardware; eg, on an 8051, and interrupt can occur when the UART receives a character. A Function is a construct of the 'C' programming language - it represents a piece of executable code that can be "called" by other parts of the program. (other languages have similar constructs) A special case of a function is when it is used to service an interrupt - commonly known as an Interrupt Service Routine or "ISR"
