i write a s/w for at89c51 which i use interrupts within. the code works fine in the simulator of keil but when i program it to the microcontroller the program doesn't work and the output doesn't change. this is a test program that i wrote when i realized that the problem is from the interrupts. this code works fine when i comment the interrupt portion i.e. all that the program does that it toggles port 2. but when i use the interrupts the program doesn't run and all the outputs are fixed with no change.
#include <REGX52.H> void Timer0_ISR (void) interrupt 1 // the smaller sample subroutine { P1 ^= 0xff; //P2 ^= 0xff; P3 ^= 0xff; } void main(void) {char x=0; TMOD = 0x22; // configure timer 0 and timer 1 to run in mode 2 TH0 = 0xff - 70; TL0 = TH0; ET0 =1; TR0 = 1; EA =1; //TR1 = 1; P0 = 0; P1 = 0xAA; P2 = 0xAA; while (1) { P2 ^= 0xff; //x++; } }
P3 ^= 0xff; if you have any external memory, this is your problem, since you do not say, this is my guess, Erik
hi, thank you for your response. I figured out where the problem is. It was with the reset circuit, as the hardware engineer didn't apply any reset circuitry so the microcontroller always enrtered an undefined state. again thank you for your response.
