problem with loop counter
I have just switched to KEIL from SDCC (it just wouldn't do what I needed!). I have a startup loop that allows some sleep time while some outboard sensors warm up. While they are doing this, I'm in a loop, printing "."'s to the uart:
Byte i = 0; //loop counter
	printf("Calibrating Sensors");
	for (i=0; i<10; i++){
		toggle_led(1,250); // delay and flash LED
		printf(".");
	printf("Loop Complete \r\n");
	calibrate_sensors();
	delay(3000);
The problem is that i is being incremented while the toggle_led() delay routine is running. toggle_led calls delay(ms), which is based is based on a 1ms timer, using timer0's interrupt. Any reason why i is 231 (vs. 2) when delay() returns the first time through the loop?
I'm using 4.51a of cx51.
