.h in assembly
.h in assemblym works beautifully as far as #define, sfr and sbit being useful in assembly.
Now I have a case of conditional compile that I need reflected in an assembly module. I have tried to make the assembly IF and $IF work based on a #define.
Using IF it works if I do a #define 1 or #define 0, that, however wil require replacing all #ifdefs in the C. $IF seems not to react to #define
any suggestions?
  • If you have recent versions of Keil assembler (older versions didn't work):
    You can write the same syntax of conditional expressions as in C, e.g.
    #if instead of "old" $IF
    In include file "numbers.h" (which is used by assembly and c modules) you define:
    #define DEVELOP 2
    In Assembly file "example.a51":
    #include <numbers.h>
    #if ( DEVELOP >= 1 )
            MOV  A,P3
            MOV  SBUF,A
    #else
            MOV  var,#0
    #endif
    It works fine.
    But: An Assembler will not work if you have defined enum's in include files....
    Martin
    #define DEVELOP 2
            MOV  A,P3
            MOV  SBUF,A
    #else
            MOV  var,#0
    #endif
    It works fine.
    Martin
