I download intsio.zip and only changed some word in main.c as following:
void main (void) { com_initialize (); /* initialize interrupt driven serial I/O */ com_baudrate (38400); /* setup for 38400 baud */ printf ("Interrupt-driver Serial I/O Example\r\n\r\n"); while (1) { unsigned char c,cCmd,cCmdLen,i; c = getchar(); if (c == 0xaa) { c = getchar(); if (c == 0x55) { c = getchar(); if (c == '@') { c = getchar(); cCmd = c; c = getchar(); if ((c+cCmd) == 0xff) { cCmdLen = getchar(); for ( i = 0 ; i < cCmdLen ; i ++) { c = getchar(); printf("%c" ,c); } } } } } } }
What processor are you using, and what clock speed? Where are your ring buffers - xdata? data? or what? Are you sure that your system has sufficient performance to guarantee that you will never miss a character?
Processor:P89LV51RD2 Clock:11.0592MHz Buffer:xdata(p89lv51rd2 ram_on_chip's xdata is 768 bytes,and xdata used 517bytes) Platform:\win2000\program\addition\communication\supperClient When baudrate been changed to 9600 or 4800,the same thing happened. sio.c never been changed,and main loop just shew as up. Best regards, Nantiangumo
Additionally,just doubly transmit and never miss bytes. Thanks.
It seems like you expect getchar() to echo the received character. (If not, the command prefix AA 55 40 etc would not appear.) In the command body, you also echo characters with printf(). (I'd suggest putchar() for less overhead.) This would cause the characters to be echoed of the command body to be output twice, once by getchar and once by printf. Is your serial output buffered, or at least synchronized with a delay loop watching TI? What if printf() writes to the SBUF before the byte written by the getchar() character has finished transmitting? Since both routines are writing the same value, you might see only one appear. I don't understand why the prefix to the command should ever be doubly echoed. You say this is correct, but I wouldn't expect that from the posted code. Only the bytes after the command length should be doubled.
Were you able to get the serial I/O example working without making any changes? I have used that code for more than 10 years without failure. Jon
"It seems like you expect getchar() to echo the received character." Yes, that is the documented behaviour of the standard Keil C51 implementation: http://www.keil.com/support/man/docs/c51/c51_getchar.htm
"Buffer: xdata (p89lv51rd2 ram_on_chip's xdata is 768 bytes, and xdata used 517bytes)" So your ring buffers are in XDATA. What size are they?
The ring buffer is ,256 bytes for transmitting while 256 bytes for receiving,and others to variables.I try changing getchar() to _getkey(),after first transmitting (prefix+234bytes),pc could receive some of prefix('@','cCmd') and 234bytes' message ,and the second time just received 6 bytes' prefix('AA','55','@','cCmd','cCmdComplex','cCmdLen');the thirst time's just like the first's,and the fourth's likes the second's ,such revolve.But everytime just transmit the same thing ,prefix + 234 bytes' message. I long for that you teach me how to resolve data in the ring buffer like these. Thank you very much. Best regards, Nantiangumo.
Now,I found that the main_loop would stop excuting when program runing in _getkey() while UART hadn't income data, in others words,the program would poll RI untill the data coming . If i want communicating with ISR_driven and running others program when serial has no incoming data,how can i do? Thanks a lot!
"the main_loop would stop excuting when program runing in _getkey() while UART hadn't income data" That's the way the SIO example works - it's just doing what it says on the tin! If this is not the behaviour you require, you will have to change it to your requirements. Me, I created a rx_available() function to check if any received character(s) are available, then I call getchar() only if there's something to get. "the program would poll RI untill the data coming " Not if you're doing interrupt-driven serial IO! If your program really is doing this, it might explain your problem... "If i want communicating with ISR_driven and running others program when serial has no incoming data,how can i do?" See above.
"it's just doing what it says on the tin!" See: http://www.keil.com/support/man/docs/c51/c51__getkey.htm Which is consistent with Keil's other products: http://www.keil.com/support/man/docs/ca/ca__getkey.htm http://www.keil.com/support/man/docs/c166/c166__getkey.htm
Well, the _getkey routine is included in the main.c file as follows:
/*------------------------------------------------------------------------------ _getkey waits until a character is received from the serial port. This may not be the exact desired operation (for example if the buffer is empty, this function hangs waiting for a character to be received). ------------------------------------------------------------------------------*/ char _getkey (void) { int k; do { k = com_getchar (); } while (k == -1); return ((unsigned char) k); }
