HI, i hav written a piece of code tat executes continuously i.e. while(1) In this there r two condition statement: if(SBUF1==0x20||SBUF1==0x7F||SBUF1==0x0FF) { //Statements } else if(SBUF1==0x53||SBUF1==0x73) { //Statements } And in debug mode i change the value of SBUF1 SFR accordingly...however wen i do "step into" it just does not enter either of these loops. Please help in this regard.
And in debug mode i change the value of SBUF1 SFR accordingly...however wen i do "step into" it just does not enter either of these loops. Once more we have someone that jump into the pool without reading "how to swim" first. Even a perfunctionary read of "the bible" would have avoided this mistake. Erik here are the links to "the bible" Chapter 1 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_ARCH_1.pdf chapter 2 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_PROG_GUIDE_1.pdf chapter 3 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_HARDWARE_1.pdf
See http://www.8052.com/forum/read.phtml?id=118327
hey thanks erik and andy for the effort from ur sides i ll b readin from the links u both hav provided hope it solves my prob
I saw the figure on pg13 n i understand tat there r 2 SBUFs....but then how does one READ the value in SBUF tat has been fed in in the simulator????? Coz I dont find n e feature like SOUT or SIN registers....i see only SBUF...also, in Keil manual, ther is one chapter "Serial Interface"-There in a program they hav used SBUF itself!!!! Please throw some lite on this issue...
Spell the words, Avoid SMS
fine
The serial port Virtual Simulation Registers (VTREG) are described here: http://www.keil.com/support/man/docs/uv3/uv3_sm_uartcommunication.htm
I m using UVision2 and the link that you hav provided seems to be for UVIsion3... In UV2 this "UART simulation " feature is not present, however, we do have simulated serial ports, which do not hav SIN ,SOUT,etc. So my question is how do i realize the same thing while using UV2?
Alrite ppl there is somthing i think i have figured out....if i write something in SBUF1 simulated register it implies, this data byte is the data that is to be transmitted (and not the data tat is received or can be copied into some variable e.g. i=SBUF1; ) So if we wish to receive data into SBUF1 then we hav to configure the correponding "receive port pin"; and then watever data we receive at this pin will be stored in SBUF1, one byte at a time..... i hope i m correct.Kindly comment on this.
Spell the words, Avoid SMS [Reply] fine and now we get Alrite ppl why would anyone want to reply to such gibberish? Erik
The MSC12xx devices are most likely not covered in your old version. Therefore you need to upgrade the system that you have. Please contact your local distributor.
but msc1210 is there in the list!!!!
