Watchdog trouble on 87C51 using PCA
I'm trying to use the watchdog on an 87C51. I've set up the PCA module 4 and it works when using timer 0 or the external pin (P1.2) to clock the main PCA timer, but when I select the internal clock to run the main timer, the watchdog activates whenever I start the main PCA timer. Sample code below:
CL = 0;         // reset main PCA count
CH = 0;
CCAP4L = 0xFF;  // set highest match count
CCAP4H = 0xFF;
CCAPM4 = 0x48;  // set compare and match
CMOD = 0x40;    // enable watchdog
CCON |= 0x40;   // startup PCA timer
When I run the last line, the watchdog resets immediately. If I change the initialization order and start the PCA timer first before enabling the watchdog, I can see that CCON reads as '0xF0', meaning that module 4 has already found a match. At that point I cannot clear those interrupt bits from CCON, even if I write a '0x40' again to it, it still reads '0xF0'. So then when the PCA counter is started, the processor is reset immediatley without getting to the next opcode.
Thanks anybody who has an idea about this!
Jeff
  • the PCA4 watchdog is a) a kludge and b) worthless.
    You do not state which brand of chip you use, but most Philips chips with a PCA has a "real" watchdog as well. The PCA4 one is there for compatibility.
    why a kludge?
    you just found out
    why worthless?
    it can be disabled and any runaway code may disable it.
    why a kludge?
    you just found out
    why worthless?
