how to assign the ram continuous without gap?
I define a struct array
struct smp
{ unsigned char attri;
unsigned char data;
} smp[50];
but I find the compiler make a gap between the array. In fact the ram is assigned as
smp[0].attri
smp[0].data
gap[0]
gap[1]
smp[1].attri
smp[1].data
gap[0]
gap[1]
so the ram of gap can not be used, then half of the ram is wasted. how can I make the ram of gap to be useful? Can the ram be assign continuous as define a struct array? Can the ram be complied as
smp[0].attri
smp[0].data
smp[1].attri
smp[1].data
smp[2].attri
smp[2].data
  • Godday,
    It seems that you have found a small bug in the CA compiler. The struct size is rounded up to the next multiple of 4, this should not be the case here.
    Until this is fixed, the following workaround avoids wasting memory space:
    #pragma save pack(1)
    struct smp  {
      unsigned char  data;
    } smp[50];
    #pragma restore
    #if 0 // Alternatively, the following is also Ok.:
    __packed struct smp  {
      unsigned char data;
    } smp[50];
    #endif
    void main (void)  {
    Peter
  • Godday,
    struct smp  {
      unsigned char  data;
    } smp[50];
    #pragma restore
      unsigned char data;
    } smp[50];
    #endif
    void main (void)  {
    Peter
