I have downloaded versions: v2.2.0 v2.2.1 v2.2.3 of the Philips Flash utility for programming via serial. In the two first versions no support for lpc2148 is provided. In the last version (v2.2.3) this chip has been added to the program options list, but [due to a bug in the program] I can not select it from the list, then I think I need version (v2.2.2) of this program as used in the help page: http://www.keil.com/support/man/docs/mcb2140/mcb2140_fp_using_lpc2000.htm BUT I WAS UNABLE TO EVEN FIND IT ON THE PHILIPS WEB SITE. Does anyone know a link to download the specific version 2.2.2 of this program? Thanks.
Hi You can run flash utility V2.2.3 from the command line. This the .bat file that i am using: START c:\windows\desktop\lpc210~1.exe "a.hex" 10000 LPC2103/2/1 COM1: 19200 1 And the bug with the Device: combo box is fixed :)
Hi Valentin,
Great, the *.bat works!
Could you share me the full parameter list of command line, I'd like to use it to Read Device ID, Blank Check, Erase, Upload to Flash, Compare Flash, Manual Reset, specify filename, etc.
Note that you're replying to a 15 year old thread.
Also note that the reference is to a Philips (now NXP) utility - so nothing to do with Keil or ARM.
You'd probably be better contacting NXP for support ...
