Accessing bytes of long data type
I know that longs are stored MSB first in memory. I need to access individual bytes of a long in order to send them out the SPI port. There are a number of ways to do this, I'd like your opinion on which approach might be best (from whatever perspective).
Two that come to mind is to simply declare the variable as a long pointer and then access each byte using the pointer. Pretty clean as far as I am concerned, but don't know if there's a better C51 way to handle this task.
Another --more convoluted, maybe even ugly-- is to avoid direct memory access and simply rotate/mask the long and cast into an unsigned char four times to grab each byte. Ugly at best.
Thanks,
-Martin
