Problem using ST-uPSD Keil uLINK to debug in uVision3
Hi, I have just bought ST uPSD33xx series development kit (DK3300-ELCD, uPSD3334D). In the kit, a keil uLINK USB-JTAG is included. When I use uLINK to debug , uVision shows the following error message :
"JTAG Communication Failure"
"*** error 122: AGDI: memory read failed (D:0x80)"
I can program the development kit using uLINK (Must disconnect the uLINK after programming, otherwise, it will not work), but cannot enter debug mode.
I observe that pin 8 in the J-TAG port, which is connected to the reset pin of the MCU, is always low. While I use another JTAG device (Raisonance RLINK-ST USB-JTAG Adapter, which work perfectly), the pin 8 is low only during program, when idle or debugging, pin 8 is high.
So, may be this the reason why uLINK doesn't work? Does it mean that Keil uLINK is broken?
Thank.
Best regard.
John
