messages longer than 3 or 4 lines couldb't be posted. is it the same for you as well
messages longer than 3 or 4 lines couldb't be posted. is it the same for you as well did you even bother to look at a few therads?
"messages longer than 3 or 4 lines couldb't be posted. is it the same for you as well" Absolutely not! As Erik says - take a look, and see how many recent posts of under 5 lines you can find!! However, it has been noted that the forum has been playing up lately - so you might have to prepare your message in a text editor, then just paste it into the window. There seems to be a timeout issue, rather than anything specifically to do with the length of the text...
http://www.keil.com/forum/docs/thread7603.asp
I am again encountering that problem, it seems that it is related to using firefox browser [which I always used to use], I think this has happened after the maintenance of Forum Servers recently. Interestingly when I use the same text in the Internet Explorer there seems to be no problem. ------------------ SUMMARY: Anyway I can use it now with Internet Explorer but still not able to post messages from FireFox browser ------------------ Thanks
