Hi, I have the Keil MCB2130 evaluation board with the LPC2138 chip. The tutorials for this board (e.g. the Blinky example) do not match with the uVision3 dialog options. For example, the linker dialogs seem to be completely different. Are there updated versions of the MCB2130 tutorials? Thanks in advance - Todd
uVision supports three different toolsets (Keil CARM, GNU, and ARM ADS/RealView). Depending on this toolsets the dialogs are different. The current documentation has some of the dialogs done GNU. You should open the Getting Started User's Guide, where the dialogs are described in detail. Reinhard
Hi Reinhard, OK, I opened gsa.chm. Under Creating Applications -> Create a Project -> Set Tool Options for Target, the dialogue for 'Options for Target' is displayed, and this has the 'LA Misc' and 'LA Locate' tabs, which I am interested in. But the tabs in detail are not described any further in gsa.chm. The Help button on the 'Options for Target' dialogue itself displays reference information for each field, but I am looking for the type of help that can be found in a tutorial, where a user is guided through the settings. Thanks - Todd
When using the Keil toolchain, you simply add the memory that is available under Project - Options - Target. The linker settings are completely derrived from this settings (when you have checked 'use memory layout from target dialog'). So typically you need not to worry about this dialog page. Reinhard
