*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
I am using the following code:
// Timer3 IRQ: Executed each 10ms
void T3TIMI_IRQHandler (void) __irq
GPIO_BitWrite(GPIO2, 15, ~GPIO_BitRead(GPIO2, 15));
TIM_FlagClear(TIM3, TIM_TO_IT);
EIC->IPR = 1 << T3TIMI_IRQChannel;
And I receive the following error:
Build target 'STR7 Eval Board RAM'
assembling Startup.s...
compiling Hello.c...
compiling UART.c...
compiling GPIO.c...
linking...
SYMBOL: GPIO_Config?T
MODULE: C:\Keil\ARM\LIB\ST\STR71x.LIB (gpio)
DEFINED: .\RAM\GPIO.obj (GPIO)
SYMBOL: GPIO_BitWrite?T
SYMBOL: GPIO_ByteWrite?T
*** WARNING L23: UNRESOLVED EXTERNAL SYMBOLS
Program Size: data=2074 const=0 code=242
Target not created
If I put the:
in the main function everything works just fine. If I put it in the ISR I get the above error. Why doesn't it work in an interrupt service routine?
regards,
