A Keil C program, it will send data "1" when it receives data "55H" on serial port. The code is as below: #include <REG52.H> void main (void) { SP=0x5F; TMOD=0x20; //timer1,Mode2 TH1=0xFD; //baudrate 9600 TR1=1; //start timer1 SCON=0x50; //#0101 0000B; Mode 3, SM2=0 enable int IE=0x90; //#1001 0000B; enable total int, enable serial int while(1); } void ReceiveFrameStateMachine(void) interrupt 5 //using 2 //serial int { unsigned int xdata c; if(TI!=0) TI=0; //clear and not care about TI if(RI==0) return; //just care RI ACC=SBUF; c=ACC; if (c==0x55) SBUF=1; RI=0; } This program runs correctly when complied in SMALL mode,however it won't send any data when compiled in LARGE mode. After compiled in LARGE mode, the asm code as below: ; FUNCTION main (BEGIN) 0000 75815F MOV SP,#05FH 0003 758920 MOV TMOD,#020H 0006 758DFD MOV TH1,#0FDH 0009 D28E SETB TR1 000B 759850 MOV SCON,#050H 000E 75A890 MOV IE,#090H 0011 ?C0001: 0011 80FE SJMP ?C0001 ; FUNCTION main (END) ; FUNCTION ReceiveFrameStateMachine (BEGIN) 0000 C0E0 PUSH ACC 0002 C0D0 PUSH PSW 0004 75D000 MOV PSW,#00H 0007 C006 PUSH AR6 0009 C007 PUSH AR7 000B 309902 JNB TI,?C0004 000E C299 CLR TI 0010 ?C0004: 0010 30980B JNB RI,?C0006 0013 ?C0005: 0013 E599 MOV A,SBUF ;---- Variable 'c' assigned to Register 'R6/R7' ---- 0015 6455 XRL A,#055H 0017 7003 JNZ ?C0007 0019 759901 MOV SBUF,#01H 001C ?C0007: 001C C298 CLR RI 001E ?C0006: 001E D007 POP AR7 0020 D006 POP AR6 0022 D0D0 POP PSW 0024 D0E0 POP ACC 0026 32 RETI ; FUNCTION ReceiveFrameStateMachine (END) The asm code seems right. but I cannot receive data "1" on the srial prot. My questions are: 1.The asm code seems right,but I cannot receive data "1" on the serial prot of my PC. 2. "PUSH AR6" and "PUSH AR7", I cannot find the definition of AR6 and AR7. What do they mean? Please tell me why instead of just telling me how to midfy the code. Thanks, Z.Y. Xu
