I want to know method, How to avoid global variable in c microcontroller programing? or method to make global variable invisible. Is there any perticular functions in built in c library?, that could be supportive to avoid global variables or hide global variables.
I don't know if I've understood you correctly, but you might consider these options: 1) Use a static local variable within a function. It will retain its value between calls to that function but be 'invisible' to the rest of the program. 2) Use a static variable at file scope (ie declared outwith all functions in the source file). It will be 'invisible' outside that source file.
How to avoid global variable So you were taught by a real Cidiot. WHAT THE #{!! IS WRONG WITH GLOBAL VARIABLES? Erik
"WHAT THE #{!! IS WRONG WITH GLOBAL VARIABLES?" Find out for yourself: take a largish project and make all the variables global, then report back with your findings.
Global variables are a perfectly valid way to communicate results from one part of the application to another. Presumably, what you want to do limit the scope of such variables so that they CANNOT be accessed by parts of the application that have no business accessing them. I hope that you already have source code that is divided into modules and perhaps you have subsystems within the application that comprise a number of modules - these mutually communicate, but these interfaces should be hidder from other subsystems. Now, for each subsystem you need to have variables that can only be accessed by modules withing the subsystem. To do this create files such as:
subsystem_name_data.c subsystem_name_data.h
subsystem_name_api.c subsystem_name_api.h
system_name_data.c system_name_data.h
Find out for yourself: take a largish project and make all the variables global, then report back with your findings. Who said anything about all the variables ? I do, of course, use lots of local variables, what I reacted to is the idiotic C thing that some teach "under penalty of severe bodily harm, do not use any global variables". How would you communicate smartly between an ISR and the main without a global variable. Erik
I just recall an incident. I worked bnriefly at a place thet had the "under penalty of severe bodily harm, do not use any global variables" rule. I had to make a variable accessible to 2 functions (b and y) and was told to do it this way:
void main (void) { struct st ... unsigned char ch ... funca (*st) funcv( *st) ... } funca (*structure) { ... funcb (*structure) ... } funcb (*structure) { .... ralph = st.ch ... } funcv (*structure) { ... funcw (*structure) ... } funcw (*structure) { ... funcx (*structure) ... } funcx (*structure) { ... funcy (*structure) ... } funcy (*structure) { .... st.ch = george ... }
unsigned char ch void main (void) { funca () funcv() ... } funca () { ... funcb () ... } funcb () { .... ralph = ch ... } funcv () { ... funcw () ... } funcw () { ... funcx () ... } funcx () { ... funcy () ... } funcy () { .... ch = george ... }
"Who said anything about all the variables ?" I think you know who it was: me. "I do, of course, use lots of local variables" Ok, ask yourself why you made those variables local rather than global. "what I reacted to is the idiotic C thing that some teach "under penalty of severe bodily harm, do not use any global variables"" Who said anything about not using any global variables? "How would you communicate smartly between an ISR and the main without a global variable." Oh, that's easy. Loop back some port pins.
Who said anything about not using any global variables? the OP Erik
"Who said anything about not using any global variables? the OP" No he didn't: "I want to know method, How to avoid global variable in c microcontroller programing? or method to make global variable invisible. Is there any perticular functions in built in c library?, that could be supportive to avoid global variables or hide global variables." I don't see the words 'all' or the phrase 'not using any' in there.
http://www.bartleby.com/61/96/A0549600.html defines avoid as To stay clear of; shun. That means all Erik
You can avoid global variables by ensuring that you only ever pass anything to or from functions via parameters & return values. Generally, this adds an overhead that increases code size & reduces execution speed. With C51, passing parameters might reduce your RAM usage since the compiler can overlay these locations. If this in turn meant that you could use the SMALL model, instead of globals in XDATA, that could mitigate the performance & code size hit...
"defines avoid as To stay clear of; shun. That means all" So you think that these two phrases are semantically identical? "Avoid global variables" "Avoid all global variables" I think your grasp of the language is better than that.
