I have a program I am converting from a Rabbit Dynamic C to Keil Arm C and cant get this one intruction to work.At first it only had a routine warning about implicit function but then I tried to add a function template at the start and cant seem to get this to work with out the error (at the bottom below). Its a simple routine that puts out strings in rom to a svga parallel port depending on the pointer when invoked. I tried the knowledgebase suggestions and they don't make it better. Any help would be appreciated. Thanks and happy Friday. David //function void vmsgo(char *); //actual /* Send out 160 ASCII characters to svga module* The x & y are preset */ vmsgo(char *mp) { char *msgp; char a; char c; c = 0; msgp = mp; loop: a= msgp[c]; if (a == 0) { goto endd; //return; } else { vgaout(a); //send directly to cygnal c++; if (c == 255) goto endd; //safety for illegal messages in debug goto loop; } endd: } //user vmsgo(&msgb); //L= //msessage const char msgb[]="L="; error in Keil is: 8500.C(1075): error: #167: argument of type "const char (*)[3]" is incompatible with parameter of type "char *"
There were instructions above the box where you entered your post about posting source code. Please follow them next time. Anyhow, this line:
vmsgo(&msgb); //L=
vmsgo(msgb); //L=
sorry. Also, that change didn't have any effect.
change didn't have any effect. I'm close to 100% certain that observation is not true. At the very minimum, it'll change the error message you get.
"8500.C(1075): error: #167 ..." Which line is this referring to?
actually the message did change a little to A8500.C(1087): error: #167: argument of type "const char *" is incompatible with parameter of type "char *"
that line you suggested I change is the error line.
"actually the message did change a little ..." "A little" to you perhaps. It's significant to me. This is all basic 'C' stuff. Do one of these things:
That's a bit of a stretch for me. I am basically an assembler guy. That why I use the Rabbit when I must do C. I was hoping to upgrade to Keil but it might be a bit much. I am about halfway in converting a 4000 statement rabbit program and this was the first "toughie".
"That's a bit of a stretch for me." Then I'll be a little more specific. Do one of these things:
vmsgo((char*)msgb);
Just to let you know that doing item 3 worked (casting). Thanks for the help.Maybe I can leave the rabbit patch behind.
"Just to let you know that doing item 3 worked (casting). Thanks for the help." Thanks for the feedback and you're welcome. "Maybe I can leave the rabbit patch behind." I've done a little Rabbit development myself. Too bad Dynamic C isn't closer to "real" C.
