Hello, We are working on RTX-51 on ATMEL 89C51 with 11.0592M.hz Xtal. we are using two code banks with 64k each. In microcontroller we did't placed any code except a pointer to the bank 0 which is containing (main) function. In main we created os_start_system with priority 0 and created two tasks in the first task. We have enabled the round_robin and placed both tasks in priority 0, but when we used os_wait function the system is hanging up on the hardware. the code before os_wait function is working . but on simulator when we watched performance analyzer it is showing that tasks are running with time slice . But why the system is hanging up at os_wait on target board ? #include <reg52.h> #include <rtx51.h> #include <inithardware.h> #include <inithardware.c> unsigned char xdata lc_status[4]; unsigned char bdata lc,ls; sbit ext1 = ls ^ 0; sbit ext2 = ls ^ 1; sbit ext3 = ls ^ 2; sbit ext4 = ls ^ 3; sbit lpsa = ls ^ 4; unsigned int xdata ext1_task[4]; void extension1 (void)_task_ 2 _priority_ 0 { unsigned char i; while(1) { EXTERNAL = PERI; i = LC1_STATUS; EXTERNAL = XRAM; lc_status[0] = i; ls=lc_status[0]; if(ext1==1) { fo_led1 =0; EXTERNAL = PERI; LED_LATCH = led_latch; EXTERNAL = XRAM; } else fo_led1 =1; EXTERNAL = PERI; LED_LATCH = led_latch; EXTERNAL = XRAM; os_wait(K_TMO,2,0); } } void extension1 (void)_task_ 3 _priority_ 0 { unsigned char i; while(1) { EXTERNAL = PERI; i = LC1_STATUS; EXTERNAL = XRAM; lc_status[0] = i; ls=lc_status[0]; if(ext1==1) { fo_led1 =0; EXTERNAL = PERI; LED_LATCH = led_latch; EXTERNAL = XRAM; } else fo_led1 =1; EXTERNAL = PERI; LED_LATCH = led_latch; EXTERNAL = XRAM; os_wait(K_TMO,1,0); } } void start_task (void) _task_ 1 _priority_ 1 { EXTERNAL = PERI; led_latch = 0xFF; LED_LATCH = led_latch; EXTERNAL = XRAM; os_create_task(2); os_create_task(3); os_delete_task(1); } void main (void) { os_start_system (1); }
