how to create a .lib
hi!
there are 2 troubles:
1. when i type
"LIBA ADD MOD1.OBJ, UTIL.LIB(FPMUL, FPDIV) TO NEW.LIB"
,keil3 tells me "error! not in debugging mode"-------pls tell me why
2. my ide is keil3 except that the complier is ads1.2,i can compile sources and output intel386 hex file,but how to create a library?
  • when i type
    And what part of the manual ever gave you the impression that you were supposed to type that command? And into the debugger command line entry field, no less?
    By reading the uVision3 (not "Keil3") Manual and finding out what it has to say about using and building libraries.
  • when i type
