i use 89lpc922, I want to user serial port mode 0 (shift register) i use 74hc164 to connect serial port but it doesn't work please help me, give me some exemple code, thank you!
give me some exemple code no, give us your "example code" and comments will be forthcoming. Erik
I want to use serial port mode 0. how do I config Port1 ?
If the examples supplied with the compiler aren't enough, you can find entire driver at: http://www.8052.com/codelib.phtml
