Memory Specific Pointer
Hi.
I m facing a problem regarding data reading from one memory to another via pointer.
I am using LARGE memory model for ROM & RAM. I defined one function in idata as below:
unsigned char func1(void) small {
unsigned char status;
unsigned char xdata *pSrc;
unsigned char *pDst;
pSrc = (unsigned char xdata *) &Obj_Xdata;
pDst = (unsigned char idata *) &status;
*pSrc = *pDst;
here, Obj_Xdata is a 1 byte data located in XDATA. But writting the code as above, i m not able to get the proper value of Obj_Xdata in the status variable.
Please suggest the way to achive this.
  • "not able to get the proper value of Obj_Xdata in the status variable."
    Then shouldn't that be:
        unsigned char idata *pDst;
        *pDst = *pSrc;
        *pDst = *pSrc;
