Banked calls
Excuse my limited knowledge on this... For proprietary reasons I must split my 8051 code so I can supply one section to a vendor who will perform testing on the product. I broke the code into Banks but am having trouble with the calls. Both with SiLabs emulator and running without the emulator the program counter goes back to reset instead of reaching the banked functions.
Details: I broke the code into two projects, built them with "unresolved externals" warnings - because the code isn't there. It is in the other bank. I use ohx51.exe and then "Hex2Bin /L131072 RP0.h00 Linked.bin" ...and... "Hex2Bin /O0x9c40 /M RP0.h01 Linked.bin" and finally bin2hex /4 Linked.bin Linked.hex.
So the unit just sits there reseting over and over again.
Any clue what I'm doing wrong? Replies are greatly appreciated!
ALSO: I need to know if it is possible to pass parameters in Banked calls.
  • You built the code with "unresolved externals" warnings.
    A banked application is still a single image, all linked together as one project. It just happens to be larger than 64KB and the compiler has to do more complicated things for a function call than just "LCALL <address>".
    If you ignore the unresolved externals, you're ignoring the fact that the linker did not know the address for those routines. It has nothing to put in the CALL instruction. And I'd even bet that the code generator uses 0 as a placeholder for the address. So, each of your unresolved externals is likely CALLing 0 -- that is, the reset vector.
    You need to build a complete image.
    I'm not sure how a vendor is going to test the product with only half the code. But if they don't need the other half, perhaps you can just stub out all those functions with dummy functions in order to link a complete image. If vendors are supposed to supply their own routines for the other half of the code, then you need to reconsider the design.
    If the image is to be statically linked, and banked with the usual methods, then you need to give them object files at least, so they can link their code with your base code.
    If you don't want to do that, then you need to invent some sort of vector table, so that the base code can locate the addresses in the additional code at run time. (This is similar to a dynamically linked library.) If you have writable program store, then you could also dynamically load the extra code. That is, you store a file that includes the relocation information for the routines you need to call, and when you load the program, you patch all the calls with the proper target addresses.
    It is possible to pass parameters to functions in a different bank.
  • the program counter goes back to reset
    So run it in the simulator, turn on recording, put a break at 0x0000, and go backwards from there to see where it came from.
    Generally said, things like
    don't actually exist. An unresolved external is an error, every time. And it's almost certainly the exact reason for your problem, too.
    If you split up the project into separately linked parts, you have to at least export the locations of the missing part to the one calling them --- in terms of PC programming with shared libraries, you need an "import library". Such a trick is relatively easy to pull off in assembly, but may prove tricky in banked C programs --- the linker will probably forget to include the inter-bank call instrumentation for them.
