can help me to find an assembly code for this : V - Communication: In our project we are proposing to use the CRC for the detection of errors and use an LFSR based random number generator to generate random bit errors and simulate the transmission channel. Figure 5: Diagram of the Communication System Two computers are linked through the RS-232 serial link and exchange data frames. The source computer generates frames as shown Figure 6: Proposed Frame Format The frame has 4 fields; the first field called the preamble has a length of 2 bytes and is used to mark the beginning of the frame. The preamble has the unique following bit pattern: Preamble: 01111111 11111110 = (7FFEh) The length field is one byte only and indicates the length of the data field in bytes. Always assume a k bytes data field. The number k should not exceed 127. The data field is the data that is effectively exchanged between the two computers. The FCS field is the sequence computed after CRC computation (Figs. 2, 3). The sequence is simply appended to the end of the data field. At the receiver, error checking is performed by dividing the received data frame appended with the FCS field by the same polynomial generator used at the transmitter. If the final result in the shift register is zero than no error is assumed, otherwise an error is reported
You must be doing the same homework assignment as Jose Mario: http://www.keil.com/forum/docs/thread6043.asp
