Reading A/D result register and output via SBUF
Using Infineon XC866-4FR
I am trying to read two A/D channel results and printing the outputs to SBUF. The results are 255 < result6 < 32607 and result7 always 0.
Here is the code:
#include "MAIN.H"
#include <stdio.h>
ubyte result6, result7;
void message( char *pucMessage );
void MAIN_vInit(void)
/// Initialization of module 'GPIO'
IO_vInit();
/// Initialization of module 'UART (Serial Interface)'
UART_vInit();
/// Initialization of module 'Analog / Digital Converter (ADC)'
ADC_vInit();
// Interrupt Priority
IP = 0x00; // load Interrupt Priority Register
IPH = 0x00; // load Interrupt Priority High Register
IP1 = 0x00; // load Interrupt Priority 1 Register
IPH1 = 0x00; // load Interrupt Priority 1 High Register
// USER CODE BEGIN (MAIN_Init,3)
// USER CODE END
// globally enable interrupts
EA = 1;
} // End of function MAIN_vInit
void main(void)
char msg[50];
MAIN_vInit();
while(1)
ADC_PAGE = 0x06;
ADC_CRPR1 |= 0x40; // generate load event
while(ADC_ubBusy()); // wait until conversion complete
ADC_PAGE = 0x02;
if(ADC_RESR2L & 0x10) // check whether the result is valid
result6 = ADC_RESR2H; // read 8-bit result
PORT_PAGE = 0x00;
ADC_PAGE = 0x06;
ADC_PAGE = 0x02;
if(ADC_RESR3L & 0x10) // check whether the result is valid
result7 = ADC_RESR3H; // read 8-bit result
PORT_PAGE = 0x00;
sprintf(msg,"\n\n\xd %d - This is the result from Channel 6" , result6);
message(msg);
sprintf(msg,"\n\n\xd %d - This is the result from Channel 7" , result7);
message(msg);
} // End of function main
// while the character is not 0
while (*pucMessage)
SBUF = *pucMessage++;
while (TI == 0) {;}
TI = 0;
return;
