Debug Communication Channel
I want to use Ulink for downloading frimware as well as the µvision debug serial window to diplay result. I can display the string but not hex values.
my code is
#include <LPC21xx.H>
#include <DebugIO.H>
#include <stdio.h>
void init_serial(void)
  PINSEL0 |= 0x00000005;
  U0LCR = 0x83;
  U0DLL = 16;  /* 57600 Baud rate @ 15MHz VPB clock */
  U0LCR = 0x03;
int putchar (int ch) 				/* write character to serail port */
  #ifdef DEBUG
  return (__dbg_putchar(ch));
  #else
  if (ch == '\n')
	   while(!(U0LSR & 0x20));
		U0THR = '\r';
  while (!(U0LSR & 0x20));
  return (U0THR = ch);
  #endif
int getchar (void)               /* Read character from serial port */
  #ifdef DEBUG
  return (__dbg_getkey());
  #else
  while(!(U0LSR & 0x01));
  return (U0RBR);
  #endif
void puthex (int hex)
  if (hex > 9)  putchar('A' + (hex-10));
  else putchar('0' + hex);
void putstr (char *p)
  while(*p)
	   putchar (*p++);
int main ()
  #ifndef DEBUG
  init_serial();
  #endif
putstr("\n");
putstr("\n The value in hex is 0x");
puthex((byte >> 4) & 0x0F);   / byte = 8 bit char value */
puthex (byte & 0x0F);
I can see the result on Hyperterminal but on serial window of IDE. I see only my srting The Value in hex is 0x and not hex values which I want to display.
where am I doing wrong.
Please help me out.
regards,
Sridhar
