I want to place some data in an array and then call this method to execute:
unsigned char IAP_ProgramUserCodePage ( char idata * ptr, // Pointer to data buffer in RAM unsigned short addr, // Page address unsigned char nb) { // number of bytes to program ptr=ptr; // avoid warnings addr = addr; nb = nb; IAP_key = 0x96; // write key value ACC = 0; // MOV A,#00H return ((unsigned char (code *)(void)) 0xFF03)(); // LJMP 0FF00H }
sorry forgot, How to call this method, and how to place data which is recieved from the UART to place it an array and the execute that above method BR Khaled
You're joking, right?
If you are trying ot use IAP with the Philips parts, take a look at the following knowledgebase article: http://www.keil.com/support/docs/2554.htm If you're using a different device and you tell us what it is you may get a response that is more appropriate. Jon
Thanks alot Jon, I fully understand now, best regards Khaled
