I have a PC which doesn't have an RS232 serial port. I use a USB-to-RS232 serial adapter cable (vivanco usb serial adapter) to connect the PC to my XC164CM Starterkit-board. When I try to debug, I receive the following message: Connection to Target System Lost Although all settings (COM port, baudrate,..)are adjusted. If I use another PC that has an RS232 serial port I can connect and debug with no problems. Does the debugger work with a USB-to-RS232 adapter, with the XC164CM Board?
