I have a PC which doesn't have an RS232 serial port. I use a USB-to-RS232 serial adapter cable (vivanco usb serial adapter) to connect the PC to my XC164CM Starterkit-board. When I try to debug, I receive the following message: Connection to Target System Lost Although all settings (COM port, baudrate,..)are adjusted. If I use another PC that has an RS232 serial port I can connect and debug with no problems. Does the debugger work with a USB-to-RS232 adapter, with the XC164CM Board?
Hi. RS232 for uVision2-3 must have serial port COM1 up COM4 with address into range 3F8-2E8H in address space PC. COM1 - 3F8H COM2 - 3E8H COM3 - 2F8H COM4 - 2E8H Eduard Jadron.
